Winston's last point is the one which is often more pertinent on sites than the ability of the voltage to stop the heart. If you're wielding a large drill or cutter next to your workmate and you get a shock then they're the ones who get injured.
You?Guess who was in charge of refueling?
An RCD can only address the duration of a current, not it's magnitude. If the impedance of your body is such that, say, 200 mA will flow through your body,then 200 mA will flow through your body, even with an RCD in the circuit. The RCD would hopefully limit the duration of the current to an extent which prevents the shock being lethal, but there is no guarantee of that.Well it takes 50mA or more through the heart reagion (one conductor each arm) for an otherwise healthy person.
We hear so rarely of people suffering electric shocks which have caused an RCD to trip that it's very difficult to know/estimate how many (if any) lives they have 'saved' by RCDs.
True, but if you have a TN installation, an OPD (fuse or MCB) would usually do the same, even in the absence of RCDs.Often the RCD trips due to the mechanical damage which normally exposes people to shocks, before the shock can occur.We hear so rarely of people suffering electric shocks which have caused an RCD to trip that it's very difficult to know/estimate how many (if any) lives they have 'saved' by RCDs.
Again, if you have a TN installation, with the 3-core cable you would quite probably have been spared those belts even without an RCD.Replacing the lead of a hedge trimmer with three-core and fitting an RCD plug has saved many an unwelcome belt.
Kind Regards, John
