Hello,
I wonder if anyone can help. I am about to install a mixer shower with a pump next to the hot water tank.
The shower comes with 22mm inlets and these are a fixed distance apart. There are also some cranked reducers 22mm to 15mm which the intructions only refer to if you need to adjust the distance between the inlets.
As I am installing from scratch I do not need to use the adjusters as I am installing new pipework.
So do I run the shower on 22mm piping all the way from the pump? Or should I convert down to 15mm at any point and if so why?
Thanks for your help.
Neil
Neil
