flexi pipe for cistern supply
J
jeepster
hi all, any idea what flexi pipe to get to connect a loo cistern to a 15mm copper pipe.
thought of one of these from screwfix - item number 18417.
That would do the job, isolation valve included, just be sure that almost 12 inches is not to long/short :LOL:
hi, the feed is a 15mm copper pipe, the connector on the cistern is a plastic male connector, the nut off a 15mm compression fitting fits onto this.
the first fix plumber put a isolating valve on the feed. rather than have too many connections i will just replace that with the pipe from screwfix.
Flex Tap Connector Valve 15mm x ½" if i wanted ones for a bath tap would they be 15mm * 3/4 ?
Yes they would
Be careful though if you have a combi with no water tank as flexi's can restrict the flow due to their smaller bore size and you need all the flow you can get with a combi to fill a bath
