DIYnot
Local | Network
   DIYnot > Forums
Local | Network
cleaning plaster off wood
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
Ish
from United Kingdom
Thanked: 1 time
PostPosted: Mon May 16, 2005 3:57 pm Reply with quote
hi
what is the best way to clean plaster of brand new wood??
a plasterer i used managed to get plaster on my new skirting boards & door frames which are unpainted/un varnished
cheers
Back to top
 Alert Moderators
kozzymodo
from United Kingdom
PostPosted: Mon May 16, 2005 6:40 pm Reply with quote
A gentle rub down with a piece of sandpaper or even a brush should move it, its actually quite soft.
Back to top
 Alert Moderators
Ish
from United Kingdom
Thanked: 1 time
PostPosted: Mon May 16, 2005 7:21 pm Reply with quote
thanks.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Mon May 16, 2005 9:08 pm Reply with quote
damp sponge should shift it with some elbow grease
Back to top
 Alert Moderators
HIGHRISE
from United Kingdom
PostPosted: Thu May 19, 2005 5:43 pm Reply with quote
You have a problem because often liquids or substances will soak into new timber and stain it because it`s not sealed in any way. Good luck.
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Fri May 20, 2005 6:27 pm Reply with quote
Dont hang around as the plaser often 'burns' the wood and will leave marks that are virtually impossible to remove.
Back to top
 Alert Moderators
aflemi
from United Kingdom
PostPosted: Tue May 20, 2008 12:22 pm Reply with quote
I'm worried now I read this. I had an extension built with about 10 new hardwood framed windows. I have a LOT of new plaster marks on the hardwood. Building work finished 6 months ago and I am getting round to decorating. I have tried scrubbing them with toothbrush, lots of elbow grease with cloth and hot water, sugar soap etc but little success.
I notice that they look fine when damp but dry out with plaster still ingrained and little improvement. I had hoped that when I come to seal them, the effect would be the same as when they are wet. From reading this topic it looks like I will struggle to clean them, can anyone recommend a sealer which will cover them up to best effect. Should I complain to the builder? I thought the marks would wash off fairly easily so didn't make a fuss when they finished.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Tue May 20, 2008 5:10 pm Reply with quote
you should not let British gypsum any where near untreated hardwood.
as said previously, plaster is very acidic and reacts with hardwood.
your plasterer should have advised you to seal the wood prior to plastering. icon_eek.gif icon_rolleyes.gif
Back to top
 Alert Moderators
aflemi
from United Kingdom
PostPosted: Wed May 21, 2008 8:36 am Reply with quote
Thanks Noseall. The plasterer was subcontracted by the buider, who has an excellent reputation and is very experienced. I find it hard to believe he has let this happen. Do you agree I have a case against the builder for him to make the best of it? Obviously he won't replace 10 window frames, but he should clean them up to best effect?
Back to top
 Alert Moderators
aflemi
from United Kingdom
PostPosted: Fri May 23, 2008 10:19 am Reply with quote
Before I go back to the builder, I want to test the result of a sealer on a small area that is badly affected and that I have got as much plaster off as I think possible. Can anyone recommend the best product for this, I want a polished sheen/silk finish. If the product is also good for the exterior, that would be a bonus..... Appreciate your input on this friends....
Back to top
 Alert Moderators
Growler
from Antarctica
Thanked: 50 times
PostPosted: Fri May 23, 2008 1:06 pm Reply with quote
It sounds to me like it's your responsibility as you don't seem to have employed a Painter and decorator to do the job, or indeed put a coat on first, If you had, you wouldn't have this problem. You've taken too long to do the wood and made a mistake.
Back to top
 Alert Moderators
aflemi
from United Kingdom
PostPosted: Fri May 23, 2008 2:58 pm Reply with quote
Growler, what difference does it make whether I have "appointed a painter" ? This is a DIY forum. The delay doesn't mean the builder is any less liable. What I'm looking for is some advice on what is the best product to use now. Anybody have any constructive suggestions please?
Back to top
 Alert Moderators
Growler
from Antarctica
Thanked: 50 times
PostPosted: Fri May 23, 2008 3:36 pm Reply with quote
Well actually it's because of the delay that you're in this position.
You delayed.
On a daily basis, Painters and decorators deal with these issues of plasterers, electricians, joiners etc ...but you left it, decided to do it yourself, and are now looking to blame someone else.
The builder isn't liable.... you are.
Back to top
 Alert Moderators
aflemi
from United Kingdom
PostPosted: Fri May 23, 2008 3:46 pm Reply with quote
Ok, let's get back to my original question as the rest is hypothetical and doesn't help fix the problem. Can anyone recommend a sealer which will cover them up to best effect?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
cleaning unprepared oak wood before varnishing 2 220 Sat Nov 06, 2010 6:31 pm
Cleaning plaster from tiles. 2 60 Tue Jun 14, 2011 5:18 am
Cleaning old paint splashes from bare brick fareplace 5 580 Sun Mar 21, 2010 7:18 pm
Cleaning brushes 16 820 Tue Jul 13, 2010 9:56 pm
Paint Roller Cleaning. 2 280 Sat Jul 31, 2010 8:08 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
