are these valves closed?
13 Jan 2011
Wolverhampton
hi there, first post. i'm trying to help a mate out and his boiler appears to be isolated. the water feed is off. but are the CH flow and return in the off position?
thank you
jake
they are off, so is the gas, so the first question before i turned them on is why were they off in the first place
looks like a ferroli,has he just moved into the house?
as saind the gas is off and should be checked,the f/r valve is also off and may be off for a reason i.e a leak on the boiler
Def looks like a Ferroli (poor sod :D )
I should imagine the property is a repo, all drained and isolated.....
