A little bit of extra dead load on the walls shouldnt be a problem from extra joists..
You have a couple of options, either add extra joists between the existing or reduce the existing joist centres maximum of 350mm centres.. 300mm works best as you can leave in every 3rd joist in and move the other two appart to drop a new one between them.. therefore you will only need to cut new holes for services every 1.2m or so.. still a pain..
Beam and mid span on a long thin room will not work so dont worry about that option any more..
