Help- dimmer switches
21 May 2003
In the process of replacing a 2 gang switch with a 2 gang dimmer except somehow wrongly labelled wires up when disconnecting old switch and can not get dimmer to work.
The 2 switches operate two different lights however there is only one mains cable into the switch containing 4 wires; red, black, yellow and earth wires. Dimmer has C,L1 and L2 terminals on both switches.
Which wire do I need to connect to which terminal on the switch?
it depends on how who ever installed it wired it.
Try this.
Yellow in L1 Switch 1
black in L1 switch 2
Red in common on switch 1 link from this to common on switch 2
Glad to help, and i wasnt't even there.
Folks i am always glad to help where i can, but if all of us "regulars" replied to the thanks we would have a forum full of thank you, OK, dont mention it etc.
But I for one do apreciate you saying thankyou when i help. I am sure the other regulars do too.
i am installing some 12 v track lighting in my conservatory and require some assistance, i am getting my power from a fused down 13 amp curcuit i then have a dimmer switch with connections L1 L2 and com there is then a chocolate block on the transformer for my track lighting
do i have to take the power to the light (transformer) first, or can i take the live from my 3 amp fused box in to the com on the dimmer then from L1 to the transformer? and put the neutral straight through to the transformer (ensuring all earths are in place). would this work for me is it the done way
Can I wire two wall lights into a light switch that has a red and black lead via a two way two gang dimmer switch so that the wall lights only will dim?
first make sure the transformer is a dimmable transformer
