Moving a flue from a combi boiler
2 Dec 2008
Bournemouth
Hello all
I am about to build a shed alongside the house and the 1st obstacle is the combi boiler flue, and just wondering what is involved in moving it.
The boiler is a worcester 28CDi combi and at present, the flue comes out the top of the boiler and goes straight through the outside wall. I have had a quick look through the service manual and it says that the max flue length is 3 metres, so no problem there. Ideally I would move it either 1 metre vertically, or 2 meters horizontally.
A question, can the 'flue extension' be done externally? and if so, is this a big job? I guess its a job for a gas safe engineer?
This is a gas safe job as flueing is a big issue in the gas regs and would need a site visit to give you the safe option
Hello Stev
Thanks for the info.
Sorry I probably didnt make it clear in my post, I have no intention of touching this myself. Just want to check what's possible and a ball-park figure of costs.
That type of flue can only be used internally!
Current flues can be diverted but not old Worcesterones.
So the only solution would seem to be to move in indoors to exit in a new position.
Maybe about 250 pounds!
Tony
Damn. Thanks for the info Agile
Not sure if theres enough room internally due to a window being in the way. Might get someone out to take a look. Or the shed might have to be smaller :(
