fire alarm activated, don't know why?
5 Mar 2008
Antrim
Hi guys,
Have a fire alarm problem, fire alarm goes off falsely but the panel shows no faults.
I checked all break glasses and all the detectors are not showing red lights as they would do in the area which caused the alarm.
Anyone got an idea whats wrong and why it doesn't show up and how to find the cause of the problem?
can you give me some info on the panel make, the detector make and ages.
this would help diagnose the fault
I would need to check out all those details.
I know most of the detectors are menvier , I will update this later on.
Thanks in the mean time
I was thinking of replacing a detector at a time with one that works to see what happens, there only are about 7 detectors.
If you have absolutely no alarm or fault indications, I would guess its an internal fault on the control panel.
also it does depend on the age of the kit,
some panel JSB(older style menvier) do sometimes generate spurious fire indications,
sometimes this is down to back up batteries and or main born interference
we usually change the panel out for a newer type (depending on age)
and also change all the detection devices (smokes) for apollo S65 series, these we have found to be very reliable and easy to wire, (even for electrical contractors)
but ensure that the batteries are ok (if over 4/5 year old, change them)
fit a low pass mains filter to the panel.
this can rectify the fault.
if not do as above, change them all out, remember smokes (inc ionisation) are usually changed after 10 years service life.
any other questions, post here and we will try to help
Oasis
