DIYnot
Local | Network
   DIYnot > Forums
Local | Network
gravel on a slope
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
Author Message
larco
from United Kingdom
PostPosted: Tue Jan 25, 2011 5:51 pm Reply with quote
I have a 30 to 45 degree slope in my garden covered in moss.
It is a pain to mantain.
I also have a tonne of golden gravel 20mm available. I was wondering if i could put this over the slope covering the moss.
I would place a weed membrane over the moss and cover it with a mesh / netting. The purpose of the mesh is to stop the first layer of gravel from rolling off.
Then I would put more gravel.
Is this feasible?
Back to top
 Alert Moderators
ursamajor
from United Kingdom
Thanked: 2 times
PostPosted: Tue Jan 25, 2011 9:21 pm Reply with quote
Must admit I'd be inclined (pardon the pun) to lay a weak dry mortar mix of say 8 sharp sand to 1 cement over the membrane and press the gravel into it as a key for the subsequent layer, instead of the mesh.
Back to top
 Alert Moderators
intercityuk
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jan 28, 2011 10:04 am Reply with quote
The trouble is it sounds like it's quite steep. I am going to put gravel on my drive but iam going to use a rienforcement that comes in squares and snaps together this is layed on sharp sand (40mm) then you put the gravel in it. Otherwise the gravel will go everywhere. Iam using a product called Hebden 40 made from recycled plastic its a little expensive but you need something to hold the gravel in place. Google hebden 40 and have a look they also sell it on ebay.
good luck
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Fri Jan 28, 2011 10:35 am Reply with quote
Be aware that if it's a driveway at the front of your property Planning conditions now apply to both new & refurbished drives;
http://www.planningportal.gov.uk/permission/commonprojects/pavingfrontgarden/
Basically you have to use a permeable material the water will soak through or provide a drainage channel to a soak away to prevent water run off into the road.
Back to top
 Alert Moderators
hillw
from United Kingdom
Thanked: 8 times
PostPosted: Thu Feb 03, 2011 7:44 am Reply with quote
I have seen a honeycomb covering before, not sure where you get it from but it was on a steep drive and seemed to hold the gravel ok.
It was a rubber I think and the honeycombes were about 80mm across.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
HOW DO I MAKE A CONCRETE SLOPE ??????? PLEASE 8 2700 Thu Aug 30, 2007 10:48 am
How to build a terrace and retaining walls on a slope. 6 1680 Mon Apr 21, 2008 3:19 pm
Landscaping a Slope/Hill In Back Garden 5 1280 Fri Aug 24, 2007 12:10 am
Close board fencing on a slope. 9 20260 Sat Jul 08, 2006 8:03 am
fencing on a slope 3 580 Mon Apr 25, 2005 10:31 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
