I have a motor which will run for 10-15mins each day and I need to connect power to it. The motor is 230v / 2100w and the length of run is around 75m from CU to motor but I will get around 85m or so to be sure.
The cable size calculator at TLC states 4mm swa. I know its only a guide but do you think I should go for 6mm to be on the safe side?
Nothing else will run of this cable, only the motor so I need to lay the cable into the trench that I have dug.
Cheers
Cheers
