Joined: 20 May 2005 Posts: 6 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Fri May 20, 2005 8:19 pm Post Subject:
mcbs
hi, i have just installed a 10.5kw rated shower, which replaced an old 7.5kw, the problem is the old 32amp fuse is not powerfull enough for this shower and i cannot seem to find one any where, its a type2 nsb,
ive been told that they are an old type fuse and are hard to get hold of , am i right? plus the shower recomends a 45amp and i have read they dont make them any more, i am a novice when i comes to electrics, can someone help! thanx phil.
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Fri May 20, 2005 8:24 pm Post Subject:
Re: mcbs
what size is the cable to the shower? it needs to be 10mm. and what is the length of the run?
Joined: 28 Nov 2004 Posts: 323 Location: United Kingdom Thanked: 0 times
Posted: Sat May 21, 2005 12:44 am Post Subject:
Re: mcbs
Type2 nsb is acually an MCB made by wylex type 2 and the catalogue reference is NSB follwed by the amps NSB32 = 32amp. It is and i am sure you may still be able to get in both 40 and 50 amps (you will need the 50) Be very careful though you also should check your cable size to ensure that is correct 10mm is what i would like to see.
TLC should have in stock
Posted: Sat May 21, 2005 1:57 pm Post Subject:
hi, i was concerned about upgrading an ncb in my consumer unit from a 32 amp to a 45amp, the cable i am sure is 6mm2 and is less than 1.5 metres from the unit to the shower, it is protected by a 30 amp rcd on the unit ,is this ok if i just upgrade the fuse?.. thanx for the replies and i hope this is a little clearer than before..
Posted: Sat May 21, 2005 2:39 pm Post Subject:
if your RCD is 30A then there is something wrong. and you need to be 100% certain of what size cable it actually is
Posted: Sun May 22, 2005 6:59 pm Post Subject:
sorry i forgot to add the m, it is a 30 mA RCD but do i still need to upgrade to 10mm2 cable or will 6mm2 cope with the load, if i change to a 45 or 50 amp mcb? thanx phil...
Posted: Sun May 22, 2005 7:07 pm Post Subject:
change to 10mm^2. the RCD protects again earth leakage, NOT overload. thats what the MCB is for. but your gonna change it for a larger type which the cable might not support. the RCD is there for your own safety
Posted: Tue May 24, 2005 6:08 pm Post Subject:
thanx for the advise, and have finnally decided to get it sorted by some one who nows what they are doing, plus im also having the lot rewired to be on the safe side, aint taking now chances anymore..
thanx for everyones advice. phil.
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
Posted: Tue May 24, 2005 7:29 pm Post Subject:
So on the basis of your original question, if you had been able to easily find a 45A MCB, e.g. in one of the sheds, you'd have stuck it in with nary a thought....
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
