bumble
Joined: 22 May 2003 Posts: 5 Location: United Kingdom Thanked: 0 times
frodo
Joined: 22 May 2003 Posts: 6 Location: Ireland Thanked: 0 times
Posted: Thu May 22, 2003 8:04 pm Post Subject: Spurs |
I'm actually not a qualified electrician but have done a fair bit of renovation and extending of circuits. I would be interested to know if all the sockets in your kitchen are on both MCB's?
In a previous house I actually had 4 double sockets on a single spur, admittedly it was a 60 amp line but my pal (who is an electrician) reckons you can have quite a few on a spur and apart from possible low voltage at the extreme end there's no real problem, just don't have everything switched on at once if you can help it!
Good Luck |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Thu May 22, 2003 8:17 pm Post Subject: |
it sounds like who ever did it has put each end of a ring onto an MCB (both ends of the ring should go to the same MCB, this is becasue if there is a fault in thoery (assuming it is 2.5 mm cable) the cable will melt first as it is protected by 2 x 30 amp mcbs meaning 60 ms could flow beofre any thing happened. (turn the MAIN switch off first and have a look)
As for spurs acording to the regs you can have one outlet per socket on the ring, but you can not take off a spur from a spur __________________ Do you like music Mr Finch?
Forum = Opinions |
