Help...hot water but no central heating
20 May 2005
Middlesex
I have a Gas Baxi Bermuda 552 combi, a Grundfos Selectric pump and a hoeywell ST699B programmer, for the last 3 days i have had no central heating, but have hot water. I have bled the rads, no air locks, i can feel the pump vibrating, the programmer is set to continuouse on both hw and ch, (Which i have pa=layed with but made no difference) boiler on which usually makes a few bangs when starting, but have had no bangs for the last 3 days? What could the problem be? Any help would be great, many thanks. :(
motorised valve most likely. Tell us what sort of valve(s) you have on the system.
the Baxi Bermuda is not a combi boiler. It is a back boiler, supplying heating and hot water via a diverter valve (if fully pumped). The problem could be that the diverter (3 port) valve is not opening to the heating circuit.
Like oilski said, we don't know what valve(s) he has yet......... :rolleyes:
May not be the valve, may just be the motor that drives the valve, is there a `click` sound coming from it? You can test the valve by taking the motor off, after isolating the electrics of course, ( fused spur)? See if the top of the valve will move freely, use pair of grips, if it does, it`s probably the motor that drives the valve that is cream crackered. If it won`t move freely it`s probably seized. You can probably free it & use a bit of WD40, to keep it lubed up, may go again in the future but worth doing & saving yourself a few bob if you have to call me out ;) If you do take the motor off, note the position of the spindle on the valve, & the position of the `d` shape underneath the motor :D
Then again it may be your roomstat, or your programmer :cry: :cry: if it`s not your motor/valve post back & we`ll go through the process of how to test the above :D :D
sounds more like cylinder stat to me or maybe air lock in coil on cylinder but hey what do know i only work for Baxi ?? :idea:
Sorry just found this little gem...yes you ONLY work for Baxi...next time you make a visit, let the forum know in advance... We`ll put banners up informing the rest of the engineers that `Gaz` is coming..maybe some of us will have the opportunity of kissing the hem of your gown... :LOL: :LOL:
