DIYnot
Local | Network
   DIYnot > Forums
Local | Network
what does a 3 port motorised valve do ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
jtritton
from United Kingdom
PostPosted: Thu Jan 27, 2011 8:27 am Reply with quote
Hi
Hoping you can help, please.
I have just had my old thermostat and programmer replaced with digital ones.
Due to the "wonderful" wiring when my original boiler went in (wire starts off grey in the boiler, ends up blue in the airing cupboard), the plumber can only get the heating to work if the 3 port valve is set to manual permantly.
Not knowing what the 3 port motorised valve does, i wondering if anyone could explain what impact this has please ?
Many thanks
Jason
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Thu Jan 27, 2011 8:32 am Reply with quote
the three port valve sends heat to either hot water tank or radiators (or both together) as requested by programmer and/or thermostats.
Back to top
 Alert Moderators
jtritton
from United Kingdom
PostPosted: Thu Jan 27, 2011 8:35 am Reply with quote
thank you.
so leaving it on manual all the time, instead of automatic, what does this do / what impact does this have on the system ?
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Thu Jan 27, 2011 8:40 am Reply with quote
You will have the heating AND hot water on whenever either is switched on. The wiring for these is not rocket science, all it needs is a little patience and some testing to find out which wire does what.
Back to top
 Alert Moderators
misterdubya
from United Kingdom
Thanked: 368 times
PostPosted: Thu Jan 27, 2011 9:54 am Reply with quote
Is it a 'Y' Plan, or a 'W' Plan?
You may not be able to have heating and hot water on together.
Mr. W.
Back to top
 Alert Moderators
keithsb
from United Kingdom
Thanked: 10 times
PostPosted: Thu Jan 27, 2011 10:05 am Reply with quote
If you search on the internet for the make and model of valve, you should be able to find the wiring diagram.
Also, if you look at the "similar topics" at the bottom of the page, you should find more help there.
Back to top
 Alert Moderators
D_Hailsham
from United Kingdom
Thanked: 1055 times
PostPosted: Thu Jan 27, 2011 5:12 pm Reply with quote
Are there any identifying numbers on the 3-port valve? If so, what are they?
Back to top
 Alert Moderators
jtritton
from United Kingdom
PostPosted: Thu Jan 27, 2011 7:20 pm Reply with quote
its a Honeywell V4073A 3 Port Motorised Valve, brand new, so the instructions are with it.
i believe its just an issue with the wiring which changes colour in the walls, so doesnt match up at either end icon_sad.gif
Back to top
 Alert Moderators
D_Hailsham
from United Kingdom
Thanked: 1055 times
PostPosted: Thu Jan 27, 2011 7:31 pm Reply with quote
If you post the make and model of your boiler, I can post a wiring diagram.
Back to top
 Alert Moderators
jtritton
from United Kingdom
PostPosted: Fri Jan 28, 2011 12:12 pm Reply with quote
its a glow worm micron 60ff boiler
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
replacing 2 port motorised valve 3 300 Sat Dec 05, 2009 5:18 pm
2 port motorised valve 2 220 Sun Jan 11, 2009 12:30 pm
SUNVIC SD2701 motorised valve/port valve? 4 6280 Fri Apr 28, 2006 6:53 pm
motorised or 3 port valve 9 980 Fri Dec 07, 2007 10:20 am
2 port motorised valve question and manifold for microbore q 9 820 Thu Sep 11, 2008 1:38 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
