I have a problem with the system it is working but the heating will not come on without hot water and I think it may need to be re-wired, or do I need to replace it? the pump and 3 point valve have been changed
Thanks Mick,
This is what I am thinking the problem is It won't turn on the heating without the water. so it's either the valve not wired right or the timers gone wrong. I am going to take a look at it tomorrow so I will have more info maybe there is an easy answer, you never know.
