DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
outside electricity
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
  View previous topic :: View next topic
Author Message
timmaiden
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 22, 2005 4:34 pm    Post Subject:
outside electricity
Reply with quote Thanks
how do i join my outside cable to the main power in the house?
thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 22, 2005 4:43 pm    Post Subject:
Re: outside electricity
thanks
depends on how much power you need and size of cable etc....
wire direct into a MCB/fuse in your CU if going to garage etc
wire into FCU on ringmain if demand is upto 13A
wire into plug and plug in, again if demand is less than 13A
if you have used SWA, all methods (esp 2 and 3) will SWA to be terminated then wired by T+E or flex
note: outside comes under part P. only way out of it is to use number 3
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun May 22, 2005 5:29 pm    Post Subject:
What sort of cable is it?
What size is it?
How long is it?
What load is it supplying?
Where does it run on its way to wherever it ends up?
What type of supply earthing system do you have?
All of these questions need satisfactory answers before you get to the connecting up stage...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
timmaiden
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 23, 2005 6:53 pm    Post Subject:
i have a steel reinforced cable running under back entry into garage its for lights and sockets(2) and will also be running a pond pump which is further up garden
sorry its 25m long
__________________
moderator
please note 10a
Back to top
 Alert Moderators
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 29, 2005 8:21 pm    Post Subject:
If you don't intend plugging much in, more than the odd lawn mower or something, and less than a couple of kilowatts at a time, I'd suggest for the time being put it on a 13A fused spur, or even as sugested method 3 terminate the cable in a box, and inside have terminal block to a flex with a plug on it . (please arrange a good cable grip if you do that though - its not my prefferred route.) It is then really just a rather superior extension lead, and can be easily totally isolated if there is any problem.
If you intend plugging large fixed loads totalling 3KW or more into the sockets of course, all bets are off, and you should really have a dedicted fuseway in the consumer unit..
__________________
regards Mike(G7VZY)
-STICKY Reference Info @ top of forum, Has diagrams & answers to common probs-
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon May 30, 2005 2:59 pm    Post Subject:
sorry its 25m long
Well, that's answered 2 of the questions, and sort of started to anwer 2 more....
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
ELectricity cable route 20 760 Mon Aug 18, 2008 2:09 am
Reconnecting to mains electricity 3 300 Thu Aug 21, 2008 11:23 pm
Twin and earth cable price & Electricity certificate 14 960 Mon Aug 11, 2008 12:27 pm
Black liquid on electricity mains pipe 7 260 Sat Aug 02, 2008 3:37 pm
do electricity meter dials turn when there is no load 2 340 Wed Jul 30, 2008 3:56 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
