Wiring lamp into two way circuit on the 4 core cable to the
1 Feb 2011
Surrey
I want to add a second hall light, close to the second 2 way switch which is fed by a four core cable. Connected to the live and neutral of this cable the lamp goes off and on out of sync with the first light. Any solutions?
You have a problem.You cannot do it like that.
There is probably no neutral in that 4-core cable (I'm guessing it is 3-core and earth?).
The way to do it is to wire the second lamp from the existing one.
See the WIKI to learn how lighting circuit switching works
