DIYnot
Local | Network
   DIYnot > Forums
Local | Network
CANDY GRAND O ,FLASHIN LIGHTS
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
cammy130
from United Kingdom
PostPosted: Tue Feb 01, 2011 7:13 pm Reply with quote
HELLP my candy grand o washing machine has started having problems i,e on a 60 wash , half way through it,l stop and the the END TIME + STAIN vanish will start to flash 3 flashes , STOP THEN 3 FLASHES AGAIN ,,help dont no wat to do
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Tue Feb 01, 2011 7:48 pm Reply with quote
3 flashes on a Candy washer usually points to a drain issue; Clogged filter, blocked/defective pump, or a kinked/blocked drain hose. Your user manual should include instructions on how to check the filter. Post the full model details if you require further information.
Back to top
 Alert Moderators
carlbontoff
from United Kingdom
PostPosted: Fri Dec 16, 2011 12:58 pm Reply with quote
The problem with the Candy flashing light problem (90mins and stain/vanish) is usually due to a blocked filter. If not then it is due to the water lever pressure switch tube being bocked by, usually, soap.
This tube takes the pressure from the build up of water in the drum to operate a switch. Older machines have a soap trap fitted which is easy to clean. With the Candy you need to undo the top of the tube and blow through it to clear it. A combination of water and blowing hard will eventually clear it. Otherwise remove the bottom panel and access the other end of the tube to clear it properly.
Clive
electronics and electrical engineer
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Fri Dec 16, 2011 7:49 pm Reply with quote
If the OP hasn't resolved this issue by now he never will, the post is 10 months old......
Back to top
 Alert Moderators
carlbontoff
from United Kingdom
PostPosted: Sat Dec 17, 2011 2:02 pm Reply with quote
It might help othe people with the same problem though! This something the manufacturs never tell you about and it is a very common problem.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint Ultima WMA63 - 5 Beeps & Keyhole Symbol Flashin 6 540 Sat May 29, 2010 3:31 pm
candy grand o go1482 fault codes again 8 260 Sat Aug 06, 2011 11:19 am
candy grand o go1482 fault codes 2 160 Wed Aug 03, 2011 7:20 pm
Candy Grand'o 146 7 blinks 3 60 Sun Jul 24, 2011 9:19 pm
Candy Grand o washing machine not working 6 1120 Mon Aug 22, 2011 4:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
