DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how do i pebble dash a wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
maximus999
from United Kingdom
PostPosted: Wed Feb 02, 2011 12:06 pm Reply with quote
Hi all, i need some advise/guidance on how to mix motor for pebble dash.
I have a 9 foot high by 9 foot wide wall that has been damaged with the frost, I am going to take the loose off to the measurements above and need to know what ratio sand to cement i use and what kind of sand i use. I know there is 2 coats to be done, the first being the scratch coat - what ratio do i mix to do this coat and secondly what ratio do i mix for the top coat which has the little pebbles in.
Many thanks for any advise Ian
Back to top
 Alert Moderators
mcluma
from United Kingdom
Thanked: 4 times
PostPosted: Wed Feb 02, 2011 12:57 pm Reply with quote
You do need plastering sand!!!!!!!!!
then the in your final coat, you trow the stones at it, not to hard, not to soft, and they will stick,
its bloody hard work
make sure the cement goes off a bit, before you trow the stones at it, otherwize they just sack down
Back to top
 Alert Moderators
maximus999
from United Kingdom
PostPosted: Wed Feb 02, 2011 1:11 pm Reply with quote
hi, thanks for the advise do you know the ratio of the mix
Back to top
 Alert Moderators
mcluma
from United Kingdom
Thanked: 4 times
PostPosted: Thu Feb 03, 2011 4:40 pm Reply with quote
mix 4 to 1 with platicizer
Back to top
 Alert Moderators
lloydycoroofing1
from United Kingdom
PostPosted: Tue Feb 08, 2011 2:05 pm Reply with quote
make sure you put fibers in the mix as well to prevent any cracks showing up after and i would paint it once it has all gone off as the paint holds the stones together allot better
Back to top
 Alert Moderators
mcluma
from United Kingdom
Thanked: 4 times
PostPosted: Tue Feb 08, 2011 4:52 pm Reply with quote
I agree with the paint
I just but an airless to repaint my wall
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Crack in pebble dash brick wall where extension joins house 34 720 Sun Dec 29, 2013 8:46 pm
Painting pebble dash 6 1140 Fri Apr 20, 2007 2:24 pm
Advice needed please - Pebble dash/ Cementing or Insulation? 3 160 Sat Dec 25, 2010 10:06 am
render/pebble dash removal and brick cleaning 7 1980 Tue Jun 15, 2010 11:16 pm
Removing Pebble Dash For Conservatory 4 2020 Sun Jan 14, 2007 12:49 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
