Viessmann vitodens 100 Boiler only produces DHW
3 Feb 2011
Lancashire
My Viessmann vitodens 100 Boiler only produces Domestic hot water and no fault codes appear and the pressure is good.
Any ideas ?
It is a known fault that the diverter valve can stick/fail. I would expect the boiler to fire up from cold and heat itself up for a few seconds if the heating is turned on.
You dont say when it was fitted but could be within a five year warrantee.
I have not experienced that failure so dont know if its possible to dismantle and clean the diverter.
Tony
Look to see if the tap symbol is there all the time. If it is, the domestic flowswitch is stuck on, usually caused by debris in the water. Try turning the tap thermostat knob fully anticlockwise; if you then can get central heating, that confirms the diagnosis.
The diverter valve on the Viessmann boiler has been very problematic. It is however very simple to replace. It is worth contacting viessmann to ask for this to be fixed under warranty. If you warranty is over ask anyway as this is a known fault. The replacement parts are reliable. Dirt in the flow switch is easily removed. This boiler is the most simple boiler ever made to repair and service.
