Current problem with vitodens 100 is: On attempted start-up in morning some days it fails to fire;
I find water pressure @ 0.5 bar. When pressure increased to 1.2 (which is pre-set cut-off pressure) it works okay but I note that pressure can swing up to approx. 3.0 bar before settling down to run okay. This has occured a few times over past month or so. On these occasions the weather temperature was in the minus zero centigrade region.
I have had various other problems with this boiler since it was commissioned Nov. 2006 into an existing oil fired, copper plumbed/steel radiator system which had been thoroughly flushed and fernoxed.
Any thoughts?
Kieran
Any thoughts?
Kieran
