| Author |
Message |
steve1978
Joined: 03 Feb 2011 Posts: 52 Location: Lancashire, United Kingdom Thanked: 2 times
Posted: Thu Feb 03, 2011 6:19 pm |
Ok folks, We did have a fully functioning showermate twin 1.4 bar, recently the thing started failing to start every time so i took it out to service it. I have re-installed it following the manual priming both side by connecting the inlet hoses first and getting a good flow through the pump before connecting the outlet side but after doing this the pump fails to work or runs for a few seconds then stops.
I have checked the installation diagrams and its installed as suggested in the manual with the pump possitioned right at the side of the cylinder with the water tank directly above.
I have allso removed both the shower head and hose but nothing seems to work.
Help pulling my hair out here.
Steve
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Mark Br
Joined: 17 Oct 2007 Posts: 782 Location: Berkshire, United Kingdom Thanked: 109 times
Posted: Thu Feb 03, 2011 7:48 pm |
If you place a magnet (moving it upwards) on the reed valve does it work?, if so your reed valve needs sorting. |
| Back to top |
steve1978
Posted: Thu Feb 03, 2011 8:56 pm |
I have checked them both and both are working fine, If i disconnect the pipework to the shower the think works fine its just when i connect everything back together then it wont work again.
My head keeps saying i am either not priming the pump right or the pump cant shove the air in the shower pipework once connected again.
Steve |
| Back to top |
Mark Br
Posted: Thu Feb 03, 2011 9:28 pm |
With the supply connected, but not the outlets (to the pipework) does it work?, you need to connect a hose(s) to check it or you'll flood the place |
| Back to top |
steve1978
Posted: Thu Feb 03, 2011 10:15 pm |
yes it pumps lovely with just the short flexi hoses fitted and feeding into a basin lovely without the pump running and even better with the pump running as you would exspect
Thats whats so confusing about all this
Steve |
| Back to top |
Mark Br
Posted: Thu Feb 03, 2011 11:09 pm |
I'd be checking the shower valve |
| Back to top |
steve1978
Posted: Fri Feb 04, 2011 10:36 am |
Valve seems to be working fine so it aint that.
This is doing my head i i can tell ya |
| Back to top |
Fluffster
Joined: 05 Jul 2006 Posts: 1111 Location: London, United Kingdom Thanked: 21 times
Posted: Fri Feb 04, 2011 10:42 am |
Have you checked if fitted the non return valve in the shower valve.
Pete |
| Back to top |
steve1978
Posted: Fri Feb 04, 2011 11:28 am |
Pete
it was working fine before and none of the pipework has been changed so i cant see it being that really.
Problem is nearest bloke who is trained to fit and repair these things is miles away otherwise i would have got someone out to look at it by now
steve |
| Back to top |
steve1978
Posted: Fri Feb 04, 2011 4:17 pm |
Hey folks
Thanks for trying to help me sort out this problem.
I have now sorted it as it was a air lock and a small piece of grit inside the pump itself jamming the pump each time it tried to start (or so it would seem.
Just a quick note to anyone reading this with a simular problem the pumps are really easy to take apart and re-assemble with a few simple tools and not half as hard as some would have you think.
Thanks again
Steve |
| Back to top |
Mark Br
Posted: Fri Feb 04, 2011 5:45 pm |
So how did it work when you ran it into the basin! |
| Back to top |
