Replacing Kitchen Unit Lights
5 Feb 2011
Surrey
I have bought some replacement lights for my kitchen units. The existing one's are on the kitchen light circuit. The replacement one's I bought have mains plugs on them. Can I just wire these into the lighting circuit?
I also bought some spare connectors but in the instructions it states the connectors are not to be used as the first connector in the installation.
Not sure if I have the wrong thing here! Any guidance appreciated.
It might be possible to arrange for them to be powered from the lighting ciruit.
But without a lot more information no one can give you a definate answer.
For example are they plugs or a plugs with a power controller ( transformer ) built into the plug ?
Pictures will help to provide an answer.
These could be wired into the lighting circuit by removing the mains plug but it is then necessary to connect them to the lighting circuit via a FCU with a 3 amp fuse in it. Either one FCU per lamp or an FCU for the first lamp and then join the lamps together as in the instructions.
