Installing central heating in a bungalow
6 Feb 2011
Kent
Good morning. I am installing a new central heating system (radiators and all the pipework) in my bungalow. Main pipework in 22mm will be running through the loft and tee-ing off in 15mm to drop down to each room. Where possible I have positioned the drops in cupboards between two rooms and then tee'd off at floor level to each room. I am having doubts about how well this will work. I have installed drain down points at each rad and manual bleeds in the loft. Any help and advice will be gratefully received.
Dave
It`d work very well if I did it like that ;)
