Help 1/4" fuel supply line
15 Dec 2009
Whitby N Yorks
I have a diesel supply from a tank into a 15mm copper pipe. I have plenty of quarter inch soft copper tubing I hope to use. So I need to get from the 15mm into the 1/4". I also would like to fit a 1/4" ball valve into the line. I have found some 1/4" valves F/F OR M/F BSP but cannot work out how I can fit them into the line.
Suggestions welcome.
Mike
Realised since posting.
What I really need is a valve with 1/4" compression fittings each end. Anyone know if these are available? Where should I look?
Mike
Thanks Terrywookfit but sorry I do not know what you mean. The fittings you mention are not familiar to me.
Mike
Use MI to copper adaptors and a BSP valve.
It is standard practice.
1/4" male iron x compression fitting at the other end.
Hydraulic suppliers such as "Thorite" still sell imperial sizes.
Sorry, completely miffed.
I have googled mi copper adaptors & still fail to see how they work. When I indicated previously I did not understand what you mean I mean exactly that. I was not suggesting it is anything but standard practice but the practice is not familiar to a retired golf professional.
Mike
