I have an Ideal boiler with 2 circuits, a gravity fed HW circuit and pumped CH circuit.
I am having a problem with 1st floor rads heating up when only HW is switched on. I have eventually located what I think is a anti gravity valve, and having researched found that this sounds like it is faulty and needs replacing.
But, I'm not sure what to replace this with, I have come across a check valve which sounds like it does the same thing, but would like some advice on what I can use as a direct replacement?
I have heard of using a 2 port valve, but would be keen on a cheap and simple fix if its possible?
