DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how to remove paint around window that has upvc frames
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
snomys
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 07, 2011 10:54 am Reply with quote
I want to take on a project myself this spring, but Im unsure whats the best approach for removing the current paint.
I want to strip the paint backon the external masonry, currently looks like a lot of layers from decades, peeling away, then Id like to prime it and repaint.
I was thinking of using a heat gun but im really worried about using that when the masonry runs right up against the upvc frames, i presume the plastic may melt or burn.
Does anyone have any idea whats the best way to do this? I also thought masking it off with foil or something, but as its a Victorian bay window that may be costly and time consuming.
Finally, can anyone recommend a good primer and masonry paint for the ledge and sill of a 1900's victorian terraced bay window.
Back to top
The following user says thank you to snomys for this useful post:
spada01 (7 Feb 2011)
 Alert Moderators
spada01
from United Kingdom
Thanked: 3 times
PostPosted: Mon Feb 07, 2011 10:30 pm Reply with quote
The heat gun will wreck your windows! I'd just sand down to teh point where you can get sight of some bits of concrete and that will hold the new paint on. I've just used standard undercoat and then masonry paint for such sills and it worked well.
Back to top
 Alert Moderators
vv2806
from United Kingdom
Thanked: 39 times
PostPosted: Wed Feb 09, 2011 11:05 pm Reply with quote
The heat gun didn't ruin my plastic windows, I am not sure if it's worth using it on the exterior though. Might be easy to sand down. If you insist on using a heat gun, buy a solder pad (something like this http://www.wickes.co.uk/Solder-Pad/invt/421643). It is supposed to protect timber and other materials that can be damaged by heat. I used one to protect the windows while stripping multiple layers of paint from the windowsill.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
removing paint from upvc window frames 5 6660 Wed Apr 14, 2010 11:31 am
Kitchen and Bathroom Sealant for uPVC window frames? 6 740 Thu Feb 25, 2010 7:58 am
How to remove filler from UPVC window frame 6 3320 Thu Feb 14, 2008 9:22 am
how to remove day old masonry paint from upvc ? 7 660 Tue Jun 23, 2009 8:59 pm
removing spilt masonary paint from upvc window frame - help 7 3060 Mon Mar 27, 2006 9:26 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
