Need serious help.No hot water or central heating and noisy boiler after emptying system to replace leaking bleed valve in living room.Switched off boiler and mains water before emptying.bled air out of all radiators after filling.switched boiler on.boiler makes a racket when opening hot water.(only hot for a couple of seconds if heating is selected).boiler makes a racket when timer comes on.water in pipe slightly warm,water return pipe cold.no radiators warm.pressure gauge normal water gauge also normal.no water tank in loft,no idea if or where pump is.VAILLANT COMBI VCW-3 T3W.New to diy.detailed help please & thanx
