Hotpoint VTD65A F-12 error code after changing belt
7 Feb 2011
Derbyshire
I've just changed a snapped belt on my sisters dryer, all went well but I've have now got F-12 coming up on the display :oops:.
The dryer is a Hotpoint VTD65A, and according to the hotpoint website the code means there's a communication error between the two boards
When I changed the belt I removed the front of the machine, and removed the connection to the display board with the blue wires, also the door switch connector with the brown wires and what I think was the something to do with the clean filter sensor (2 red wires with spade connectors at the bottom middle).
I have checked and rechecked the wires to make sure there not broken and are correctly fitted.
So now I'm stumped, does it need programming? or have I messed something up?
Thank you
Andy
Check conection j9 on the pcb. Make sure all connctions are tight.
Thanks, I'll check that connection and see if it helps, is j9 the blue wires to the display pcb?
Sorry for the late reply.
Andy
