Can anybody please help solve my problem?
After putting in the code the exit delay tone responds as it has always done allowing sufficient time to exit and lock doors..
Recently the entrance delay tone no longer sounds but the audible alarm activates as normal after about 10 seconds(movement picked up by sensor?) if the code is not input to the keypad after entering the house.
I have tested the system and activated all detectors all of which are positive. I have one remote radio detector which appears is working properly.
However the Testing System Instructions does say that as each detector is activated the keypads will beep twice. I only have one keypad and it only beeps once.
In short, the problem appears to be simply (I hope) that the entrance delay signal no longer works but does not stop the system operating.
Any advice from you knowledgeable people out there would really be appreciated as I'm not very up to speed with this kind of thing.
Thanks a lot.
chrisaf
Thanks a lot.
chrisaf
