Salus rt500rf wired to Glow worm boiler 50FF
6 Jul 2008
Berkshire
Hi
Can someone please tell me what I am doing wrong,
I have a time in the airing cupboard that is set to turn on the heating and hot water at various times during the day, but I have no theremostat, I try and control the radiators via the thermostic valves on the radiators.
So I have wired a Salus RT500RF into the boiler as per the instructions, having removed the link between SL and 9 on my boiler and everything seems to be working well, when the timer in the airing cupboard switches on the heating, the thermostat controlls the heat and the boiler responds fine. However when the timer switches on the hot water, nothing happens?
I assume that the link needs to be in for hot water and heating to be controlled by the timer? So if I keep the link in as well it operates as before and the thermostat is not needed?
Many thanks
JB
You need to wire it into the wiring centre, or in some cases the programmer. What programmer is it?
You need to find which is the heating on (live) terminal at the programmer. Then you to trace this wire back to the wiring centre, where you disconnect the wire from the terminal block, and connect it to COM on your new stat's receiver.
Then you connect a wire from NO on new stat receiver to the connection on the wiring centre block where you removed the other wire from.
Lastly, connect N on the stat receiver to the neutral connector on the wiring centre block.
Make sure you replace the link in the boiler. If in doubt, contact a plumber to wire the stat up.
Hi
I found the heating live wire in the wiring centre and connected as described, and it works a treat. I was forgetting that the thermostat is actually only a switch.
Regarding connecting the power to the stat receivert, I actually connected the stat receiver N and L connections to a constand N and L in the wiring centre, it seemed to imply that in the useless Salus instructions.
Many thanks for your assistance
Regards
JB
