Hi
Have an old cottage I've gutted and am getting on with the plumbing now. I'm trying to work out where to site the pump in the system to drive the water secondary heating the cylinder and also move the heated water around the rads. My guess is to put it where the water returning from the heat source enters the cylinder. If this is right which side of the pump would I put the off pipe to the rads - before the pump or after? Will I get enough pressure like this or do a need a second pump sited on the rad cycle? I know there was just one pump on the old system, should have drawn a diagram before I ripped it out 
Cheers
Cheers
