correct method of installing a strap on boss?
6 Aug 2009
West Midlands
Hi just want some clarification on the correct way to fir a strap on boss to a soil stack
do you silcone the flange and fit the strap
or solvent cement it to the stack and tighten the strap ?
Use a 54mm holesaw to cut hole
Clean edges of hole with file
Solvent weld strapon to stack
Use rubber boss to conect 32 or 40mm pipe
Simples :)
Once you do it you will think that was easy ;)
Check on holesaw size - it can vary between manufacturers. I would solvent weld the whole strap as well as the flange, and also solvent weld around the hole where the flange will fit on. I prefer glued bosses to rubber ones.
I use solvent weld right round the strap, some dont go right round with a screw to hold together.
I think that this thread is totally disgusting.
Discussing Strap on's and Flanges on a family forum :eek:
