Find answers and ask questions direct at [link removed]
For more information on [link removed]
[link removed]
Question:
What is the formula for calculating the voltage drop for a set length cable and how to i work out what the maximum length cable is my circuit can be?
Wrong Answer:
(ref. IEE wiring regulations Appendix 6 Table 6D2)
Right answer:
(ref IEE Wiring Regulations Appendix 4 Tables 4D1B, 4D2B, 4D3B,
4D4B, 4D5, 4E1B, 4E2B, 4E3B, 4E4B, 4F1B, 4F2B, 4F3B, 4G1B, 4G2B,......
Question:
Can I use 2 dimmer switches on a two way light circuit?
Wrong Answer:
Unfortunatly not. One needs to be a standard 2 way switch.
Right Answer:
Yes you can but you have to use dimmer switches designed to work together in this way.
Question:
What is supplementary equipotential Bonding (Supplementary Bonding)?
Wrong Answer:
Supplementary Equipotential Bonding is connecting together conductive parts of an electrical item and non-electrical item such as an electrical shower unit and the copper pipe work of the bath in order to prevent the occurance of a dangerous voltage between them under an earth fault connection.
"conductive parts of an electrical item"? - What,
all of them? Would that be safe?
"non-electrical item such as ...the copper pipe work of the bath". Even if the pipes are not extraneous-conductive-parts? Would that be safe?
Height of sockets, switches & controls
"The building regs require that all switches and socket-outlets be installed so that all persons including those whose reach is limited can easily use them. Sockets-outlets and switches should therefore be installed at a height of between 450mm and 1200mm from the finished floor level."
Wrong.
I can't be *rsed to look for any more confusing, badly written, incorrect rubbish on your site, riddled with grammatical and spelling errors.
Go away, you pointless and incompetent waste of space.
