DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Grant Vortex Condensing Combi 26 hot water problems
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
didspip
from United Kingdom
PostPosted: Sat Feb 19, 2011 3:45 pm Reply with quote
I have a problem with my Grant Vortex condensing combi 26 Oil boiler.
When I run the hot water for a bath after a few minutes the water runs luke warm, turn off the hot tap and wait a few minutes and it is hot again.
It always used to work ok.
The other thing I have noticed is I can hear air bubbles traveling around the heat exchanger pipes and the water store. the heating is ok and quiet.
Its almost as if there is not enough water in the store?
The boiler is only 4 years old but has had a few problems needing the boiler to be drained and re filled a number of times.
Leaking washer on heat exchanger - leaking flow switch washer - leaking auto air vents and leaking filling loop taps.
I have replaced the filling loop, air vents and washer on the exchanger.
When I re fill the boiler via the filling loop does this also fill the water store?
Any help as to the cool water issue would be appreciated.
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 348 times
PostPosted: Sat Feb 19, 2011 4:09 pm Reply with quote
Have you checked the TMV?
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Sun Feb 20, 2011 9:55 am Reply with quote
In what way? it is set ok
Back to top
 Alert Moderators
moliver34
from United Kingdom
Thanked: 2 times
PostPosted: Sun Feb 20, 2011 6:42 pm Reply with quote
if its not the TMV; then more likely the pcb for the heat store is faulty.
contact; www.grantuk.com
ask to speak to the technical department who will be able to assist you.
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Tue Feb 22, 2011 7:07 pm Reply with quote
Thanks for the reply but can you tell me how I check the TMV? icon_question.gif
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Tue Feb 22, 2011 7:10 pm Reply with quote
Thanks for the info, can you explain why I hear air bubbling through the store and heat exchanger pipes when the hot water is running?
Back to top
 Alert Moderators
oilhead
from United Kingdom
Thanked: 229 times
PostPosted: Tue Feb 22, 2011 8:46 pm Reply with quote
Check heat store AAV for operation. Is the cap open?
Are there any manual vents on the pipework you can bleed?
Is the DHW ht exchanger scaled? How does the flow of hot water compare to cold water flow?Is the flow pipe to the TMV hot when the tap starts to cool down?
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Wed Feb 23, 2011 8:11 am Reply with quote
Thanks for the reply.
AAV on heat store has been replaced and the cap is open but I never hear air coming out even when I drain the system and re fill? does the water in the store drain when the system is drained and re fill when I fill the system back up?
All manual air vents have been bled.
Four year old boiler, will the ht exchanger be scaled after this period? if so do I need to strip it out to check? clean or replace?
Doesn't it use the ht exchanger for the central heating?
As for the TMV flow pipe I will check that later when I run the bath and get back to you.
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Thu Feb 24, 2011 8:46 am Reply with quote
I can confirm that The flow pipe to the TMV also cools down when the hot water cools down, normally it is too hot to touch.
Does this mean the TMV is b*****r?
Back to top
 Alert Moderators
leakydave
from United Kingdom
Thanked: 65 times
PostPosted: Thu Feb 24, 2011 9:01 am Reply with quote
What do the heating pipes do when you run hot water? Do they get hot even if the heating is off?
Back to top
 Alert Moderators
oilhead
from United Kingdom
Thanked: 229 times
PostPosted: Thu Feb 24, 2011 11:24 am Reply with quote
Does this mean the TMV is b*****r?[/quote]
No, it means that the problem is within the controls of the DHW operations.
Does the burner start up when HW is demanded? Possible flow switch problem.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Thu Feb 24, 2011 6:06 pm Reply with quote
With oil on the way out and prices rising daily why not consider an alternative fuel source?
[img]
http://img.allvoices.com/thumbs/image/609/609/73717055-moammar-gadhafi-on-fire.jpg
[/img]
Anyone know why the picture will not display here? Click on the link until its corrected!
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Fri Feb 25, 2011 7:32 pm Reply with quote
Does the burner start up when HW is demanded? Possible flow switch problem.[/quote]
Burner starts up ok every time. Flow switch was replaced last year due to intermittant hot water. This gave hot then stone cold water and I could hear the relay clicking in and out. I have Hot then warm water with no relay clicks. When it runs warm if I turn the tap off for a minute or two it is back up to full temp.
Yesterday as an experiment whilst running the bath I tapped the TMV lightly with a hammer thinking that if it is scaled up this may free it off. After this the hot in pipe stayed too hot to touch and this morning I ran a full bath without it going cold. Does this seem feasible or is it just a coincidence?
Back to top
 Alert Moderators
manortim
from United Kingdom
Thanked: 606 times
PostPosted: Fri Feb 25, 2011 7:35 pm Reply with quote
What is the water in your area like for hardness or do you have a softener?
What happens if you run the tap slowly?
Back to top
 Alert Moderators
didspip
from United Kingdom
PostPosted: Tue Mar 01, 2011 7:41 am Reply with quote
According to Anglian Water the water in my area is Vert Hard.
I have had a bit of success using an un conventional method based around everyones advice that the TMV may be scaled.
Whilst the bath was running I tapped the TMV with a small hammer, as I was doing this all of a sudden the hot in pipe became too hot to touch again, as it should. I was then able to run the full bath without heat loss whilst having the heating on.
I think I may have dislodged some scale?
Does this sound possible?
When the boiler was installed nearly 4 years ago it was a cash barrow job and I suspect there was no inhibitor used.
If so once I have replaced the TMV and the bleed valves again what is the best inhibitor to tackle limescale?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
Grant Vortex condensing oil boiler 15/26 Problems 12 3580 Wed Apr 25, 2012 1:55 pm
Grant Vortex 26e combi condensing water running hot and cold 4 160 Sat Oct 04, 2014 2:01 pm
Grant Vortex Condensing Combi 26 - no hot water 16 320 Sat Jul 12, 2014 6:41 am
Grant Vortex Condensing combi 26 - pressure gauge help 4 140 Thu Jul 10, 2014 10:13 am
Grant Vortex Pro External Electronic Condensing Combi 21kw 4 480 Tue Nov 03, 2009 11:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
