DIYnot
Local | Network
   DIYnot > Forums
Local | Network
ferroli f24 domi compact f37 flashing
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
coopegas83
from United Kingdom
PostPosted: Mon Feb 21, 2011 7:01 pm Reply with quote
hi guys install boiler about 2years ago, customer rang to say f37 flashing which is low water pressure i have reset boiler and away it went call back to say constantly having to reset boiler. i installed new pressure switch to eliminate and also water in system clean i am now unsure as to what i do next as it is still throwing up f37 icon_mad.gif any suggestions would be greatly appreciated
Back to top
 Alert Moderators
compheat
from United Kingdom
Thanked: 348 times
PostPosted: Mon Feb 21, 2011 7:28 pm Reply with quote
I had the same thing last week, boiler losing pressure but no sign of any leaks
It was the secondary heat exchanger/recuporater which leaks internally and the water goes down the condense drain.
Ferroli quoted me 285+vat making it 342 for the part.
This boiler is a load of Cr#p
Back to top
 Alert Moderators
ecowarrior
from United Kingdom
Thanked: 2590 times
PostPosted: Mon Feb 21, 2011 7:32 pm Reply with quote
Common fault mate do about 5-6 a year. they do come up on ebay but usually 2nd hand boilers are sold because of this issue. Same one fits all so that helps a bit
Back to top
 Alert Moderators
coopegas83
from United Kingdom
PostPosted: Mon Feb 21, 2011 9:25 pm Reply with quote
in this case the boiler isnt losing pressure the customer or myself have not had to top the boiler up at all
Back to top
 Alert Moderators
ecowarrior
from United Kingdom
Thanked: 2590 times
PostPosted: Mon Feb 21, 2011 10:57 pm Reply with quote
Look at blocked press gauge. Whist drained down check expn vess. charge to 1 bar. There are no parameters to check press electronically. Give gauge good rodding & look inside pump housing where it fits (not easy if u have the one that comes out the back) This area does sludge up. If the switch is doing its thing at (I think .8bar) the gauge may b reading 1.5 and looking good when its not. So it looks OK at 1.5 but its really kicking out at just below .8 and kicking in at .9. but the gauge is moving from 1.5 - 1.6?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
ferrolli domi compact showing - f37 4 780 Tue Jun 03, 2008 6:08 pm
Ferroli DOMI CompactF30B upgrade to wireless smart thermosta 2 60 Fri Oct 03, 2014 5:58 pm
*SOLVED* Biasi compact 28s CH failing rapid flashing light 3 400 Wed Jun 10, 2009 9:35 am
Glow-worm Compact 100P Low Water Pressure Flashing alarm 10 320 Tue Dec 14, 2010 11:58 pm
M96.24SM/C BIASI RIVA COMPACT HE FAULT LIGHTS FLASHING 5 60 Mon Jan 07, 2013 10:13 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
