What is the ideal setup for the waste pie to belfast sink connection? I have install the standard waste system but it leaks!
Agile said:They only used lead 46 years ago!
This poster says he fitted a "waste pie" whatever that is.
It is not always appreciated that there is a unique size of waste fitting for Belfact sinks. When that is used it should fit as easily as any other.
Tony Glazier
Jasonb said:London does not have the overflow "bump" running down the side.
Whats all this nut & washer stuff, I usually fit Villeroy & boch ones that take a standard 90mm basket strainer waste. Plenty of plumbers mate around the top part as the ceramics are quite often slightly distorted, the rubber washer takes care of the joint underneath.
Jason
