DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
LV lamp wattage
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
jonathan.hancock
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 7:40 am    Post Subject:
LV lamp wattage
Reply with quote Thanks
Hi. Does anyone know if a 50W LV lamp with electronic transformer current is calculated the same as a regular 50W bulb? ie 50W/240V = 0.2A and 50W/12V = 4.1A. Which, if any, calculation do you use? Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 31, 2005 9:31 am    Post Subject:
It is always I=P/V
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
jonathan.hancock
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 9:35 am    Post Subject:
ban-all-sheds wrote:
It is always I=P/V
ok. But do you take the voltage to be 12v or 240v?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 31, 2005 9:36 am    Post Subject:
What is the voltage rating of the bulb?
__________________
Back to top
 Alert Moderators
jonathan.hancock
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 9:39 am    Post Subject:
12V
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue May 31, 2005 10:03 am    Post Subject:
There you go then - use 12V.
__________________
Back to top
 Alert Moderators
jonathan.hancock
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 10:18 am    Post Subject:
I am a little confused. 50W at 12V is 4A per lamp. So you are suggesting that 4 lamps will take 16A. That can't be right. The circuit is only rated at 6A.
One of the electronic transofrmer manufactures states that the input current is approximatelt 20 times less than the output current. So the i/p current for a 50W bulb would be 0.2A which sound a bit more like it. Any thoughts?
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Tue May 31, 2005 10:26 am    Post Subject:
The power is always the same, 50W (ignoring inefficenies atm)
current = power / voltage (form P=IV)
so if you work out 50 / 12 that gives just over 4A, this however is on the secondary side of the transformer, make sure your cable is rated accordingly.
if you work it out for the primary side of the transformer, the voltage is 230, so that is 50/230 which gives 0.20.
Just remember that power (the wattage) is what stays the same both side of the transformer, not current
EDIT: the reason Iout = Iin x20 is becuase Vout(12V) = Vin(230)/20 (it doesn't work perfectly, becuase we do calculations with 230, when in actual fact tha volatge will more likely be nearer 240, and as everything is relatd by P=IV, and P is constant...
Back to top
 Alert Moderators
jonathan.hancock
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 31, 2005 11:05 am    Post Subject:
Thanks Adam 151. That makes sence now.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 16 times
PostPosted: Tue May 31, 2005 4:59 pm    Post Subject:
It is always I=P/V
for lighting that is pretty damn close to true and it seems most sparkys assume that to be true all the time. However be warned that in an ac system it is not true in general.
Back to top
 Alert Moderators
backtothebeer
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 14, 2006 11:43 am    Post Subject:
[quote="Adam_151"]The power is always the same, 50W (ignoring inefficenies atm)
Hello All,
My electician insists that a 50w Halogen Dichoric GU5.3 12V bulb for a ceiling downlight does not actually use 50w of mains electricity.
Do they use 50w - e.g. 10 of them would be 500 watts and for cost of electricity to me I take that as half a KWh ?
thanks
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 24 times
PostPosted: Wed Jun 14, 2006 12:48 pm    Post Subject:
thanks
Yes. 500w is 500w whatever the voltage. The amount of power is the same.
Approx. 42 amps at 12V, and 2.1 amps at 230V.
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 14, 2006 1:40 pm    Post Subject:
You might be getting confused between wattage and light output. As Crafty said, 500watts of energy is 500watt of energy whichever way to cut it. However, that is the energy rating of the lamp, not its light output which is measured in lumens.
For example, a 35watt florie will use around 35watts of energy, (a bit more with internal losses) however, the light output will be a lot higher than an equivalent filament lamp.
The same applies to halogen lighting, the lumens/watt of energy used is higher than the lumens/watt of tungsten lighting which may be what your sparks was trying to say
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Wed Jun 14, 2006 1:49 pm    Post Subject:
This is an old thread, you'd have been better off starting a new one, but anyway, seeing as I'm a regular in this forum, I'm still here icon_lol.gif
unless he is being predantic about it because it doesn't actually use any electricity straight from the mains icon_wink.gif , then he is wrong, watts are a measure of the rate of transfer of energy, that means for the transformer to be supplying the lamp with 50w, it must be drawing 50w from the mains (unless its magicing energy out of thin air icon_lol.gif )
The only slight exception (well not really, but if you interpret the labeling wrong...) to this rule are energy efficeient lamps, they are generally sold on what wattage normal lamp they give out equivelent light to, but take less power to do so (again, no magic, they just dont create anywhere as near as much heat) and typically one equiv. to 60w takes 12w. Anyway thats a side point
Sadly the occasional electrician doesn't seem to get this (Probably spent his time at college smoking and swapping porno mags at the back of the room icon_lol.gif )
Quote:
Do they use 50w - e.g. 10 of them would be 500 watts and for cost of electricity to me I take that as half a KWh?
Yes, that is correct, ten 50w lamps will take 500w, which is half a kilowatt, which means that have them on for an hour and you'll clock up half a Kwh on your meter
Hope that answers your question, though I seem to have digressed a little
Back to top
 Alert Moderators
backtothebeer
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jun 14, 2006 1:58 pm    Post Subject:
Thanks for the replies,
I was concerned that each light would consume 50w
The sparky said that as they are 12v, due to the step down process they don't actually use 50w.
the actual bulb is
http://81.29.94.80/sourceandselect/Applications/catalog/search/KeywordSearchFrameset.asp?Keyword=LV50MF
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
2 way dimmer switch wattage 2 320 Wed Nov 01, 2006 11:35 am
Low wattage panel heaters on dedicated circuit 7 340 Wed Dec 06, 2006 7:49 pm
Maximum Wattage 7 420 Sat Apr 14, 2007 2:00 pm
Remote/ touch Light dimmers - wattage question? 3 1140 Tue May 01, 2007 11:32 pm
Wattage for Double oven 8 400 Wed Oct 04, 2006 3:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
