Hotpoint wt540 list of error codes
27 Feb 2011
Berwickshire
Do any one have a list of error codes for a hotpoint washing machine WT540
The problem i have with my washing machine is the wash light stays on and nothing works. Will not take water in will not pump or spin.
I also notice that the light for the doot interlock is dead even though the door locks.
Any ideas.
Motor brushes worn. For error codes use search at the top or check me out I posted error codes many times on here.
hello i found you are quite knowledgeable about the WT540 SERIES, lights 2 and 4 plus the power light is flashing, load the machine and turn it on, the machine starts to fill up and as its about to start turning the lights start flashing then it does an emergency empty till theres no water then it will keep going till it stops then it goes quites and lights keep flashing, ive tryed the filter and cleaning the pump, no bits just some dirt plus you can hear it drain the water out, we thought it was damp and had a dehumidifier sat next to it for 2 weeks, and nothing, please help quick, no clean clothes, btw i have electronic engineering experience,(pcb designer) but i dont want to start pulling at the pcb just yet without asking.
christopher.
