Ferroli Falcon 11
Gut
5 Mar 2011
Boiler would not light for D.H.W. had the D.H.W.sensor changed and the hot water now works BUT at a high temperature . The D.H.W. temperature regulator knob has no effect what next could it be
[/wiki][/youtube][/url][/list][/list][/code][/quote][/u][/i][/b]
is the filter and cartridge in the flow switch ok? what's the flow rate from a hot tap?
Flow switch OK -both filter & cartridge OK Flow rate 2.5 litre/min +
Still wil not modulate
  • Thanks
Reactions: Gut
Which sensor was changed?
D.H.W. Sensor
Which dhw sensor?
The DHW hot water sensor on hot water outlet
Domestic hot water flow
The dhw flow sensor is not on the dhw outlet.
How about a partnumber to determine which one has been changed? Or a photo, or a description.
Hot water sensor part no 800320
