DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how to join polycarbonate sheets?!?!
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
koolkev1
from United Kingdom
PostPosted: Sat Mar 05, 2011 4:28 pm Reply with quote
I've started a project of making greenhouse but being an amateur in DIY, I was looking for help on how to join the sheets together? Glue is not an option but is there some sort of "fitting strips" a bit like laminate flooring?
if so please let me know!
thank you
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Sat Mar 05, 2011 7:58 pm Reply with quote
You usually buy galzing bars for twinwall polycarbonate. How thick is the poly and where exactly are you doing the joins?
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Sat Mar 05, 2011 7:59 pm Reply with quote
glazing*
Back to top
 Alert Moderators
koolkev1
from United Kingdom
PostPosted: Sat Mar 05, 2011 8:36 pm Reply with quote
they are 10mm depth, 2.5m length, 0.7width
and on the edges?
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Sat Mar 05, 2011 9:17 pm Reply with quote
Instead of a thick glazing bar you could use plastic H-section running a bead of glazing silicone along the section before you slide the poly into it. Proper glazing bars are better though.
Back to top
 Alert Moderators
koolkev1
from United Kingdom
PostPosted: Sun Mar 06, 2011 4:20 pm Reply with quote
thank you very much!!
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 651 times
PostPosted: Sun Mar 06, 2011 11:14 pm Reply with quote
you will need intermediate support for the poly without proper bars at at least 2 points along the 2.5m length and maybe only 1 with proper bars but you need to consult the manufacturers requirements and off course the good advice from people here icon_biggrin.gif
Back to top
 Alert Moderators
hillw
from United Kingdom
Thanked: 8 times
PostPosted: Mon Mar 07, 2011 12:43 pm Reply with quote
You need to make sure you use a silicone that is suitable for use with Polycarbonate, not all are.
There is a product called fixall, which will stick and seal if you choose to go with the cheaper H section rather than a proper glazing bar.
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Mon Mar 07, 2011 6:45 pm Reply with quote
Our Ford transit bumper is stuck on with fixall. It's blimmin' marvellous aint it?
Back to top
 Alert Moderators
hillw
from United Kingdom
Thanked: 8 times
PostPosted: Tue Mar 08, 2011 7:16 am Reply with quote
thats the best use yet of it though!!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Polycarbonate Roofing Sheets 7 2260 Fri Oct 19, 2007 10:13 am
replacing part of a flat roof wth polycarbonate sheets 2 1100 Sat Aug 12, 2006 3:01 pm
Polycarbonate Sheets 2 940 Wed Jan 30, 2008 3:13 pm
Slipping Polycarbonate roof sheets 4 360 Wed Jul 14, 2010 6:46 pm
Polycarbonate Roofing Sheets 4 140 Wed Oct 31, 2012 11:41 am
DIYnot
