billm
Joined: 01 Jun 2005 Posts: 30 Location: United Kingdom Thanked: 0 times
Posted: Wed Jun 01, 2005 3:36 pm Post Subject: hot tap draining |
I cut off the cold at the mains and the hot supply with the wheel besides the cylinder, then drained both hot and cold supplies at the ground floor sink until they both stopped.
Mid way through the tap swap job, the hot supply starts leaking and seems to get worse as time goes on - prolly loosing about a pint or so. I think it was due to air getting in the pipe ? Anyway it made fitting new sink taps a wet affair until I got the pipes re-connected.
How can I avoid the hot tap leaking like this in future .. maybe empty the sistern completely ? |
kevplumb
Joined: 18 May 2004 Posts: 19144 Location: Tennessee, United States of America Thanked: 400 times
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Wed Jun 01, 2005 6:36 pm Post Subject: |
it may have a been a pipeful - from someone opening an upstairs hot tap! |
brumylad
Joined: 06 Oct 2004 Posts: 830 Location: United Kingdom Thanked: 1 time
Posted: Thu Jun 02, 2005 6:51 am Post Subject: |
you could hire a pipe freezer. or buy a freezing aerosol in a can. You need to work quick with the later though. |
JPC
Joined: 10 Aug 2004 Posts: 1409 Location: Leicester, United Kingdom Thanked: 0 times
Posted: Fri Jun 03, 2005 3:24 pm Post Subject: |
seems easier to either bung the cwt or run it empty..then slap on a new gate valve if indeed its letting by...
could have been a pipefull as chris said but obviously he drained by opening both upstairs and downstairs taps ?! __________________ Jamie |
