Both have advantages and disadvantages. Wet is expensive to install compared with electric, but is far cheaper to run. I would estimate the running cost of a wet (gas fired) system to be about a third of that of electric.
Be careful when comparing. Some of the electric versions are only designed to provide background heat, or take the chill off a ceramic floor, not provide full heating.
