DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Security light and overide
Author Message
dingodeano
from United Kingdom
Thanked: 13 times
PostPosted: Fri Mar 18, 2011 2:02 pm Reply with quote
Hello all.
Customer wants a pir controlled light in garden. Havent chosen fitting yet although some timeguard ones you can switch on- off quickly for constant use independent of pir.
However customer dosent want fused spur on wall by nice french doors. is there a security light on the market than can opperate via a switch wire aswell as the pir?
Thanks.
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Fri Mar 18, 2011 3:06 pm Reply with quote
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 939 times
PostPosted: Fri Mar 18, 2011 3:16 pm Reply with quote
They can also switch into constant on mode after power cuts or other disturbances to the mains supply.
My method is to use a PIR without any such programming features and a pair of switches to provide full manual control. One switch removes all power ( Over ride OFF ) the other switch when on links Live to Switched Live from the PIR to put the light on ( Overrides the PIR ) using 3 core plus earth from switches to the PIR and twin and earth to the light fitting.
I find separating the PIR and the light fitting makes the coverage easier to set up. My prefered PIR is the Steinel IS 2180-2 as its sensing area can be set up to cover irregular shaped areas.
EDIT type number changed from IS 2180-5 to IS 2180-2
Back to top
 Alert Moderators
shadysands
from United Kingdom
PostPosted: Tue Sep 06, 2011 10:46 am Reply with quote
[quote="bernardgreen";p="1935263"]
With regard to the two switches could you be a little more explicit about all the connections between main supply,switches, PIR and light . A diagram would be most helpful although not sure if its possible with this system.
Many thanks,
Brian.[/u]
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 939 times
PostPosted: Tue Sep 06, 2011 10:59 am Reply with quote
PIR with overrides
PIR with overrides
Back to top
 Alert Moderators
shadysands
from United Kingdom
PostPosted: Tue Sep 06, 2011 11:26 am Reply with quote
bernardgreen wrote:
PIR with overrides
PIR with overrides
Many thanks for the diagram. A great help.
Just one thing. Does it not damage the PIR when it gets a live input to the output terminal when it is being overidden.
Many thanks,
Brian.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 939 times
PostPosted: Tue Sep 06, 2011 11:48 am Reply with quote
It is very unlikely that any damage will be caused to any PIR sensor provided that the live supply is still ON to the PIR's Live when the over ride ON is applied to the Switched Live. Therefore the Live to the ON switch must be taken from after the OFF switch and not direct from Live
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1163 times
PostPosted: Tue Sep 06, 2011 7:42 pm Reply with quote
If I may, Bernard, I suggest a slightly more elegant version.
I have found that the two switch solution is confusing for some.
I usually install the following.
The switch is an MK Grid switch one of these:
http://www.tlc-direct.co.uk/Products/MKK4899.html
It is a changeover switch with a centre off. So
Up is normal (PIR controlled)
Centre is off and down is over ride (on).
The above refers to the way I usually install the switch and does not refer to the diagram as I nicked Bernards original!
There is no problem with the over ride feeding into the switched output from the PIR provided you use a PIR with a relay output (most have this).
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 939 times
PostPosted: Tue Sep 06, 2011 8:04 pm Reply with quote
Taylortwocities' method is more user friendly.
I have used a three position rotary switch on a panel but that probably would not conform to BS7671
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Overide switches 20 200 Fri Dec 30, 2011 5:38 pm
Security light not working after dining room light fitting 32 480 Mon Jan 28, 2013 9:27 am
Adding a security light to my garage 2 500 Tue Jul 01, 2008 10:09 pm
Security Light with PIR 4 240 Tue Aug 12, 2008 5:57 pm
Security light nightmare, please help! 14 1040 Thu Aug 14, 2008 10:11 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
