Could someone please tell me the maximum earth fault loop impedance for a BS1362 3A fuse or where I can find the info. I need both 5sec and 0.4 sec disconnection times. The 13A spec is in the regs but not the 3A.
I was told by an NICEIC inspector to add it to a minor works cert for a fused spur supplying a spa bath. He said not only to mention the 32A ring breaker Zs but also to split the box and add the spec for the 3A fuse as well. What do you reckon?
The tables are for specific devices such as the BS1362 etc so as long as the readings fall within the specs of that you are ok, so no need to bring the rating into it?
