I have a Bosch Worceter Greenstart 24i system boiler.
My system has 2 zones and 2 motorised valves.
It uses a Heatmiser 2 channel Wireless Programmable Thermostat.
The problem is that the boiler pump seems to run continuously in the boiler (24 hours a day). Recently it burnt out and was replaced under warranty.
This problem appeared to exist (at leat intermittently) on the system before the old boiler was replaced (the valves were not replaced). All appeared to work ok for the 1st month or so of use after the boiler was put in.
I want to avoid this happening again and could do with advice as the the likely location of the fault so I know who should be looking at it.
1. Boiler (over run not working properly?)
2. Motorised Valve
3. Heatmiser Porgrammable Thermostat.
4. A wiring fault.
or..
The plumbers have asked Bosch Worcester to look at the boiler and a BW engineer is coming out tomorrow but I expect will say their boiler is working fine.
Any help would be greatfully received.
2. Motorised Valve
4. A wiring fault.
or..
