DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Building over Sewer Pipes
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission
Author Message
bars03
from United Kingdom
PostPosted: Mon Mar 21, 2011 10:30 pm Reply with quote
Hi
I am looking at building a conservatory to the rear of my terraced house. This will involve building a full height wall to the neighbours side and a dwarf wall for the rest. I have the problem of Sewer pipes (foul and water) running under the proposed build sight (approx 4.5m under surface) and an inspection cover.
I was just wondering on a couple of things.
Would either or both building regulations and water authority approval be required when building the foundations over the sewer pipes?
When building the foundations. I understand in these situations that I would have to set the foundations from the invert of the sewer pipes. What gap is recommended between the pipes and concrete footings? I assume packing the gap with sand is ok before placing the lintel over the pipes.
In regards to the inspection cover has anyone had experience where they have been given permission to close off the hatch completely? I was just wondering how likely this would be. I would prefer that there isn't a hatch within the conservatory but if I can't close it off, I will just build it up as I would envisage moving the hacth would be an expensive job.
Cheers Login to view this image Login to view this image
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Tue Mar 22, 2011 12:32 pm Reply with quote
Just a little confused as you say ďfoul & waterĒ pipes; but both pictures appear to be the same & show what looks like the foul drain, is there another drain run?
Is this your own property? If itís a private sewer on private property (you need to check) then itís yours (& your neighbours) responsibility & your LWA wonít be interested, they will only be concerned about what you discharge into it. Conservatories are exempt from Building Regs. so your LABC wont be concerned either but you should certainly ensure what you do as far as the foul drain is concerned meets Building Regs.
You will find all you need to know in Part H of the Building Regs here:
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADH_2002.pdf
I would advise to move the foul drain outside the cons base if you possibly can. Failing that, it makes sense to ensure there are no problems with the existing drain before covering it up & it would be prudent to replace the section running under the cons with a single length of new pipe, bedded & protected as per current BRís. You really need to loose the inspection hatch; you can get air tight hatches that you can tile but ask yourself if you really want one inside your cons & I wouldnít advise you just close it up without being sure you have suitable roding access elsewhere! From the photo, the chamber doesnít seem to be at a junction so it should be feasible to do away with it & fit a new one outside the cons base but which side you put it will depend on distances to the adjacent hatches not exceeding the maximum; to keep within the maximum distance you may need to fit a hatch either side. The extra work is inconvenient but the additional cost neednít be that much & a small price to pay for peace of mind especially if you later have to dig up the cons base to fix a problem icon_cry.gif . Not much work for a man with a mini digger (if you can get one in the back) who could dig out for the cons base, new trench & chamber(s) + around a Ĺ days ground works to fit the new inspection chamber(s) lay a new one piece pipe, & backfill it all; you might find a man with the digger who can do the lot in a day. Strictly speaking it should be re-inspected by LABC but if you do it as repairs to a damaged pipe. icon_wink.gif
My own 5 x 5m cons has a foul drain (not shared) running right under the center & I did it as above but did not have to install a new chamber. Itís been there for 6 years now & no problems.
Back to top
 Alert Moderators
jeds
from United Kingdom
Thanked: 423 times
PostPosted: Tue Mar 22, 2011 2:00 pm Reply with quote
First thing really is to check to see if this is a private drain or public sewer? Your sewer provider should be able to tell you (normally on the phone) from the address and postcode.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1230 times
PostPosted: Tue Mar 22, 2011 5:29 pm Reply with quote
If that is the case i would say it renders the job not just difficult but nigh on impossible.
Is that another pipe we can see running through the inspection chamber?
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Tue Mar 22, 2011 7:41 pm Reply with quote
Must confess that didnít register but I count 7 courses so got to be a typo; 450mm I reckon.
Back to top
 Alert Moderators
Fluffster
from United Kingdom
Thanked: 41 times
PostPosted: Tue Mar 22, 2011 7:42 pm Reply with quote
Looks like 2 pipes to me. One with an access cap looks about 6". They could be seperate drains run in the same trench with the surface water protected being enclosed.
Pete
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1230 times
PostPosted: Tue Mar 22, 2011 8:15 pm Reply with quote
Richard C wrote:
Surely you can see t'uther pipe Rich?
As Fluff has said, it appears there is an access cap on top.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Wed Mar 23, 2011 8:05 am Reply with quote
noseall wrote:
Surely you can see t'uther pipe Rich? As Fluff has said, it appears there is an access cap on top.
Think I can make it out now & if that is a pipe, it looks to be rather larger than the open 110mm alongside. Not seen one like that before; which is which do you reckon, surface water under the hatch?
Back to top
 Alert Moderators
Fluffster
from United Kingdom
Thanked: 41 times
PostPosted: Wed Mar 23, 2011 8:30 am Reply with quote
It may be a storm drain.
Pete
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission All times are GMT
Page 1 of 1
Jump to:
shared sewage pipes 5 260 Sun Dec 11, 2011 12:53 am
Are there any regs relating to underground fresh water pipes 5 1860 Thu Nov 11, 2010 9:37 pm
Can I put pipes through a stud wall with fireboard on? 7 480 Tue Sep 21, 2010 3:32 pm
Soil pipes 5 220 Thu Apr 26, 2012 4:45 pm
Regs re waste pipes 13 1620 Sun Jun 07, 2009 9:15 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
