DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vokera Compact 28 red light problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
kryder
from United Kingdom
PostPosted: Tue Mar 22, 2011 7:57 pm Reply with quote
I have been having problems with my boiler for over a week now where the red light keeps coming on I have it covered with Scottish gas and they have been out on 4 separate occasions first they cleaned the venturi pipes, then replaced the CH sensor then today the engineer replaced the PCB.
All of which got the boiler starting again however a couple of hours later when I ran the hot water the red light came on again icon_sad.gif
the engineer who attended today said the only other thing that could be done is a power flush but this would cost us 450. can anyone please give me any other further advise on what to do please i'm at my wits end?
Back to top
 Alert Moderators
grahamtheplumber
from United Kingdom
Thanked: 3 times
PostPosted: Tue Mar 22, 2011 8:25 pm Reply with quote
does anything in particular happen before the light comes on.does it happen more at particular times or during hw or heating use?
Back to top
 Alert Moderators
Ray84
from United Kingdom
Thanked: 31 times
PostPosted: Tue Mar 22, 2011 9:55 pm Reply with quote
it could be a number of things, Usually without any indication or it doing it while present you'd go down a process of elimination, changing both central heating and hot water sensors, do u you know if both were done? after that its quite common for the ignition pcb to go faulty then the most expensive part is the main pcb.
I had one last week that didnt it while i was present though and endedup being an air pressure switch.
red light will also come on if the boiler overheats but once cools usually comes off without the need to go in and reset so you can be almost 100% sure a powerflush wont fix anything.
Best to phone them back out tomorrow and if theyre not willing to help ask to speak to the area service manager and explain the problem
Back to top
The following user says thank you to Ray84 for this useful post:
kryder (23 Mar 2011)
 Alert Moderators
kryder
from United Kingdom
PostPosted: Wed Mar 23, 2011 10:17 am Reply with quote
red light comes on more during hot water use
I have them coming back out this afternoon so I will ask about the air pressure switch and if they changed the HW sensor fingers crossed it gets sorted
Thanks for your comments
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3522 times
PostPosted: Wed Mar 23, 2011 11:56 am Reply with quote
This is a more difficult boiler to fault find as the indication can be triggered by many different causes.
Apart from overheats or sensors the ignition PCB is a common cause. The APS is easy for any competent engineer to test.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
vokera compact 29 mtn Solid red light 3 100 Mon Jun 30, 2014 9:21 pm
Vokera Compact 29 Yellow light 2 100 Mon Jan 13, 2014 7:30 pm
Vokera Compact 28, Red Light on, locking out & not firin 8 2920 Sun Jan 06, 2008 1:59 pm
Vokera Compact SE 28 Red Light 2 80 Sat Oct 22, 2011 8:20 pm
Vokera Compact 24 Red Light 2 320 Tue Feb 16, 2010 10:29 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
