Pressing & holding the On/Off button causes the indicator lights to work correctly, but as soon as you remove finger from the spring loaded button, all the lights go off. Would guess that on/off button should electronically latch via the control board. Have removed mains power for 60 secs in the hope of a 'hard' reset, but no fix. Is there anything obvious to check or fix or must it be a replacement control board?
